CORE 4D Image to Map node plugin
Double spiral
For animation I would use Mospline since it has a lot of animation posibilities/parameters.1 -
Double spiral
Well.... I've asked (and still asking) for a Helix 2.0 with myltiple modes like Logarithmic. Archimedian and Double but primitives won't ever change in fear of compatibility break with older projects. But you could try it just on a Symmetry Object ...3 -
Double spiral
Hi all How can I do a double spiral? It should animate from zero central point and both ends should grow at same time thx -
Problems with getting an alembic export of a retimed cache of an X-partilces sim
But Alembic is supposed to support re-timing... simple animation offset. What kind of re-timimg do you want ? -
I have an x-particles simulation that's been cached and re-timed. I need an alembic export of this so that I can send it to a render farm that doesn't support X-particles. I can get an alembic export of the UNcached simulation, using thinking particles, but I'm not able to then bring that back into c4d and re-time it, because it doesn't allow for interpolation. If I try to cache my simulation, the thinking partilces just don't seem to recognize it. Is there another way to export an x-particles simulation? Or get the thinking particles workflow to recognize the cached particles? Thanks for any assistance!
